Make sending fax easy by learning faxing without a fax machine
Asked By 5 points N/A Posted on -
Hi.
I do not have a fax machine, and I have to send and receive a lot of fax these days. Is there any way possible to save me from the plight of buying a fax machine? Is there any way for faxing without a fax machine? Please reply ASAP. Thanks in advance.
Answered By 5 points N/A #125711
Hi.
There sure are ways of faxing without a fax machine which is very easy to understand and use as well. There is software available these days which can very well convert the documents to PDF format. Next, there are options such as Interfax service which can fax directly by using the Google docs. Open the document; click on fax this, type the fax number of the recipient and your fax will be delivered in no time.
You can also use your computer as a fax machine and send as well as unlimited receive fax at $10/month using services such as fax.com or my fax by scanning documents on the PC and then send them using the e-mail. You can try looking for a printer with multiple functionalities such as fax, scan, print, etc. It will be helpful if it has an auto document feeder. They are available for not more than $100 and are likely to be useful in the long run. Hope we helped.
