Hi,Â
I am a regular computer user and I use the internet connection regularly.
I am using a broadband internet connection.
But from some days I feel my connection is a bit slower than before.
I check the connection with another computer. It is ok there.
But this is not working on my computer. What is the problem, I can not find out?
Can anyone tell me its remedy?
This will be a great help for my part if anyone can solve this for me.
jakie
450 points
How to speed up my Internet Connection?
Hello Dear Russel,
You can increase your internet speed by following some steps. These steps are helpful to increase your internet speed in a good level. For doing this, go to the run start menu.
Write gpedit.msc on the dialog box of run command. Then press enter to run it. A new window will be opened.
Select the local policy from the left side of the window and open it.
Now go to administrative templates of local policy and select the network section of administrative templates.
Select Qos packet Scheduler from the network.
Now open the Limit reservable bandwidth from the right window. Set the value for Bandwidth limit. In the side window of Bandwidth limit enter o and click ok. Now restart your computer. Now taste the faster internet with your old connection.
This will fix your problem too. I am hoping that you are satisfied.Â
Thank you.
Hi Russel,
Clean your browser files using Ccleaner it wipes out history, temp, internet files, cookies etc. Â
Here is the link where you can download the program.
After you download, just install it into your system.
When installation is finished, double click the shortcut icon on the desktop, when it’s open click the cleaner tab > and click the run cleaner > just repeat the process until there is nothing to delete to your browser files.
Used also a TCP Optimizer it helps to speed up your connection, here is the link
Hope this can help,
louis
Dear Russel Nesson,Â
Internet connection speed also partially related to computer performance that is why we need to basic maintenance on your PC.
1. Regular checking of home network equipment and router.
2. Optimization of cache or temporary Internet files.
3. Contract with Internet service provider (ISP).
If you follow the above I think Internet connection speed will be better than current status.
Thanks and Regards,
Louis
