Make Your Document Look Attractive By Learning How To Make Wordart
Hi. I am not very fond of a computer which is why I am not familiar with most of the programs it contains. I need to add WordArt to a document which I have prepared. How to make WordArt? Please reply ASAP. Thanks in advance.
Answered By 0 points N/A #93321
Hi. To learn how to make WordArt, first open MS-Word from the start menu or by right-clicking on the desktop and then selecting the option to create a new Word document. Next, open the file in which the WordArt is to be added. Place your cursor on the point where exactly WordArt needs to be inserted. From the toolbar which appears on the top of the screen, select the insert menu, click on picture option and then select WordArt from the options provided. Amongst the styles which are available, select the one which you think best suits your file. Select it and then click on OK.
As soon as you click on OK, type the text which needs to be inserted in the document in the dialog box will appear. The text can be formatted as well as moved by clicking on the text box and dragging it. The text can be copied, pasted as well as colored. Hope we helped.
