Nina Wilson
810 points
Posted on - 02/21/2013
Hi there,
Is there any free software (or even paid ones) that let you create animated gif email signatures?. I have seen some web based applications but they are far too limited when it comes to choice. I preferably to create the animated Disney gif email signature.
Making an animated gif email signature with disney characters
Hello, Nina! It’s really interesting to use animated email signature. I also use it occasionally. You can get various software through the internet. They are able to make as your desired signature items as well as you can also generate. I can assist you with this http://softwaretopic.informer.com/disney-gif-email-signature/ website. Here you can get different type of animation for using as a signature. Thanks!
I know about some paid softwares that you can use for creating GIF email signatures.
Links:
If you need to create your own animated GIF signatures, you need to do the following: (assuming you are using outlook)
1) Save the required GIF, by downloading a free picture or buying a paid picture.
2) Select Tools > Options from the menu in Outlook.
3) Go to the Mail Format tab.
4) Click Signatures. under Signatures.
5) Highlight the signature you want to edit.
6) Press Ctrl-A.
7) Hit Ctrl-C.
8) Press Esc key three times.
9) Create a new message in Outlook using rich HTML formatting.
10) Click in the body of the new message.
11) Press Ctrl-A.
12) Now hit Ctrl-V.
