Making split view file manager
Some changes I want to make in my split view file manager. For this purpose, I need some tools for file browsing. Which tool will be suitable for this purpose?
I’m not sure what application is it that you want to change its view or display to have a split appearance on the screen. Since the part of the program you want to change is on its visual representation after opening it on your computer, most of the time this feature is found on the View menu if this is available on your program’s sets of Menus.
If this menu is not available in the program or it doesn’t have any option to change the display, try going to its Settings to have a check on the available options that are presently enabled and running. Majority of the program’s functionality are activated on the Settings menu. If you didn’t find it there, check every options and menus available in the application.
