simon john
40 points
Posted on - 02/05/2013
Hi there! Is it possible to do rotating text Foxit 5? If so, can anyone help or give some tips on how to make it possible. I need urgent response and will really appreciate it so much guys. Thanks in advance.
Making things possible like rotating text Foxit 5
Hi Simon John,
You can do rotating text in Foxit reader 5 by right clicking in the page you want to rotate, and click "Rotate right"
Hope i helped you.
Cordially.
You should always familiarize yourself with the keyboard shortcuts to increase your productivity in every program you use. In case of the Foxit Reader 5, the shortcut for rotating the text right is "CTRL" + "SHIFT" + "+" and the one for rotating left is "CTRL" + "SHIFT" + "-". All shortcuts are available for overview and customization by doing the following:
1. Right click on the free space in the menu bar and click "Customize toolbars".![](https://www.techyv.com/sites/default/filesx2/users/Wangwe%20Amos/foxit-5-reader-rotate-text-custom-shortcuts.png)
2. Click on the "KeyBoard" and then assing the new shortcut below.
