Malware virus attack in my Blog site
I have a Blog site.Malaware virus attack in my Blog site.plz help me How to remove Malaware virus in my Blog site?
dear Nahid,
what is your problem with the web site. i need more information to give you a solution. why you are telling that your site is attacked ? what is the reason ? sometime when you type an website name in the address bar  it will load some malware warning site or fake antivirus website instead of website that you want. this happened due to a malware installed, or malware behavior in side your computer. to remove this you can use a malware detection software ( like malwarebyte, spybot ). or if you can edit registry manually you can overcome this problem ( its depend on the threat level and the malware type )
i'm confused with your question. you mean that you are not directed to your website or you are not allowed to login to the control panel of your website ? or something has happened to your website content ? can you just please explain. then i can give you a solution
thank you
