Malfunctioning of motherboard monitor for Lenovo ThinkPad X20 laptop
Minty nicky 50 points N/APosted on - 09/05/2012
Hi bloggers, I just bought my Lenovo ThinkPad X20 last month, I installed a software motherboard monitor for Lenovo, the first time I used the software was good enough and has an accurate result but after a week when I open my laptop and tried to open this application I noticed the motherboard temperature was really high reaching 63 degrees Celsius. Anyone can suggest if this is really normal for a brand new and newly open laptop? Hope to solve this problem soon. Thank you!
Hello.
Your case is quite normal for a brand new laptop. They get heated up quickly.
Here are some steps to keep the laptop cool.
1.      Never work with the laptop by placing it directly on to a cushion or bed. They get heated up quickly as the bed or cushion blocks the inside air to come out of the laptop and blocks the cool air from going in.
2.      Place your laptop on a cardboard or a wooden pad while using it on your bed.
3.      If you can spend some money, buy a cooling pad.
4.      Cooling pad helps in maintaining the temperature of your laptop and keeps it cool.
It’s very common for laptops to heat up because of its compact built. The easiest remedy you can do is to use a cooling pad. Try HAVIT 5 Fans Laptop Cooling Pad. This cooling pad is for 14 – 17 inch laptops. It costs $24.99 and available in blue, black, and red colors.
Carantee Laptop Cooling Pad 5
It offers 30-day money back guarantee with full 1 year manufacturer’s warranty and free lifetime technical support. Another one to check is Carantee Laptop Cooling Pad 5. This cooling pad is for 12 – 17 inch laptops. It costs $29.99 and available in blue color. It features seven level adjustable stand, five powerful quiet fans, two USB ports and LED lights, and removable baffle and non-slip mat.
1....
