After turning on my PC, there is an occurrence substance locution something such like:- MBAM assets unexpectedly terminated, and saying to purview the circumstance log. The protection-log has the mass:
Administrator ERROR UtilityReadFile failed with error code 32
Administrator MESSAGE Protection stopped
Otherwise, Malwarebytes is running and working properly! What do I impoverishment to do, if anything, to fix this difficulty? Thanks.
Malware Bytes Error on Startup
Hello Carlton,
That is probably just a temporary problem with the Malware Bytes application that could be fixed by doing the following:
Press Ctrl + Alt + Del, and then click on Start Task Manager.
In the Task Manager window, you will need to click on the processes tab.
From the list of processes, locate the processes Malware Bytes is running and end them.
Close the task manager window.
After that restart the computer in order to refresh the settings.
You shouldn't be able to see the error after the computer restarts.
Hope this helps.
Carl
