Jiggy Hason
Posted on - 11/16/2011
Hi! Yesterday I installed .Net Framework 4 to my computer. Recently I tried to back up in Mamut (my business software), and a message appeared. Is my .net framework 4 compatible to the software that I am using?
That I think the error is related to the .net framework that I installed.
Please give me some Idea.
Thanks
MDataTools.exe – NET Framework Initialization Error
Unable to find a version of the runtime to run this application.
OK
Mamut Business Software Initialization error.
Hi Jiggy,
That error occurred because it is not compatible with microsoft.net framework 4.
I suggest you to download and install the latest version of Mamut Business Software.
You can also follow the instructions below:
Go to the link and update your page
Read the information regarding updates before you download/install
Click the latest version which you are going to download
Select run and follow the installation instruction
Here is the link which you can find more information
I hope it helps.
Zorian
Yes, this is a problem related to the .NET framework used. I think you installed other versions of .Net framework, so the program that you’ve using is not able to recognize a stable version of .Net.
In order to solve this please do the following:
First download and install the .Net Framework Cleanup tool (this will clean up the version that can cause problems within your system)
Now download and install the .Net framework that was cleaned in previous step.
Install now the .Net Framework required by your application (I suggest you to use the latest one)
Now run your application.
I hope this will fix your problem.
Have a great day,
Aabel
