Managing computers synced with iPhone & itunes
How to manage computers synced with iphone & itunes? Can you tell me how to turn on a song on iphone using itunes, when iphone is connected to PC?
Connect your iPhone on your PC or laptop and make sure that iTunes is installed properly. The iPhone device should appear on the left side of iTunes. From there you have to click the arrow pertaining to show other parts of the iPhone. If you press it will show options like music, movies, etc and from here, you have to select the music option. Then a playlist will appear on the main display of iTunes. List of music will start to feed you playlist and then just simply select the music file that you want to play. The iTunes has its own player and it will play in the iTunes window without going to another music player.
I hope this helps you with your question.
To turn on a song that's on you iPhone using iTunes, you simply need to connect the iPhone to your computer and make sure it's turned on. Your iTunes software will synchronize itself with the phone and will be able to reflect what the phone has inside. It will save a copy of the songs on the phone into the computer. From there, it will show the list of songs under music and you should be able to play the songs through iTunes from there. If you also have music that's saved on iTunes, you can synchronize the phone and iTunes so that the phone will have a copy of the songs as well.
