Managing The Data And Server Using The Virtual Machine Manager With R2 And Making It Easier.
virtual machine is a machine which a system inside a system which doesn’t have any link with the original OS which we are using in the system. The virtual system we can use anything and do any sort of changes in the system but it will not affect any of the internal systems it has some impact on the system on which we are running the virtual machine.
To use the virtual machine with the virtual machine and server r2 follow these steps:
You need to have the at least 4 GB of memory and have
You need to have SQL server 2008 or 2012 or above
You need to have the server 2012 or above
You must be a member of the active directory
You must have the domain which should not exceed the character name more than 15 letters
You must be connected the SQL server and have aname to your server and follow the steps which have discussed in the above question regarding the operation manager and SQL server installation.
Everything that we have till now all the:
All these will be used in the system centre and any server her we have used the server r2 for our convenience, You can use any server there are many server available in the market you can get everything there and also you can use this server for your own usage or for your office purpose for your clients or users.
