Hello experts!
I have downloaded Easy 1-2-3 Form Builder a few months ago.
It's for my Joomla website development projects.
I just installed 123 form builder Joomla component/module.
I don't know how to fully take advantage of its features such as questionnaire and form creation.
Is there any manual 123 form builder Joomla component that's made available in the web?
Manual 123 Form Builder Joomla Component Available in the Web
Hellow Sandra Teylor,
It is very easy to deploy 123 Contact form into Joomla.
Just follow the procedures
First Download the extension.
Unzip the archive
You should use one of two vearsion Joomla and Joomla 2.5.
Joomla 2.5 contains one package pkg_123contactform.
Go to your joomla administration panel.
Click on the tab extension in horizontal menu at top of the page
Choose the option "Extension Manager"
You’ll be taken to the Install panel. In the first section, Upload Package File, click the Browse button, select the package (or the two plugins for Joomla 1.5), then click Upload & Install.
For Joomla 1.5., go to Extensions → Plug-in Manager and type 123 in the Filter box. Two entries will remain in the list: Button – 123ContactForm and Content – 123ContactForm. Both of them need activation. Simply click on the two icons in the Status column to activate them.
Click on Button – 123ContactForm to access the extension settings. On the right side of the screen, in the 123ContactForm box, you need to provide your 123ContactForm API Key. To get it, go to your 123ContactForm account → My Account section. If the API Key is not yet enabled, press Create now. Copy the API Key and paste in the API Key box in your Joomla administration interface. Click Connect.
The extension is now up and running. There are two ways of getting forms to Joomla:
1. While you’re editing a Joomla article, click on the icon Insert Form that shows up in your menu. Make sure you are logged in to your 123ContactForm account. Select the form that you want to publish and click Embed.
2. Go to the Get Code & Publish section of the form in your 123ContactForm account, click on the Joomla tab on the left side of the page, copy the code that you find there and paste in your Joomla article.
Thanking you
Shifflet Laurel
