Manually disable integrated video card on Dell desktop?
I need help on disabling my integrated video card connected on my Dell PC. It just stop on working so I don't have a video. I have a new one here that I can install but first, I need to disable the old integrated card connected to my PC. My friend told me that I can unplug it but I could not find a plug to disable it. Any suggestions?
Answered By 0 points N/A #190274
This is really simple you just have to follow these steps and you will be able to disable the integrated video card.
1. Click on the start menu type device manager and press enter.
2.  Now in Device manager click on “"display adapters"" here click on the graphic card and disable it.
3. Now shut down the computer directly or remove the power cord. Now open the case to install add in video card.
4. Close the case and plug the power cord and turn on your computer.
5. Go to BIOS settings and check whether the integrated video card is disabled or not.
6. Save BIOS settings and reboot.
Your video card is installed so enjoy.
