Manually Removing Corel Components from the Windows Registry
40 points
Posted on - 12/19/2012
Hello friends,
What is the process of uninstalling corel from regedit? I want to uninstall my Corel application in regedit, can you give an illustration or a step by step process instruction to get this done properly? I don’t want to make some any trouble by using regedit.
Thanks and Regards,
Travis Nelson.
