David Mills
30 points
Posted on - 01/29/2013
There are many varieties of motherboards those have prepared by new technologies. Windows loading is most important when considering about a motherboard. Which type of motherboard is very faster in windows loading?
Many types of windows loader motherboard with new technologies.
Hello David,
I can tell you that there is no so much difference between the motherboards, but yes there are some of them which can start windows very fast. It sounds strange but the cheapest motherboards with few features seem to get to the booting Windows stage on the easiest and quickest way.
Hi David,
Nowadays, mostly all motherboard differs on the hardware functionality that users can integrate into the computer. But, in terms of speeding up the process of loading windows, the type operating system user installs will play the vital role on it. Also, how the user set up the system configuration will be a big factor. Please see the attach image below for the detailed process.
1. Go to Run command.
2. Type msconfig to go to system configuration.
3. Navigate to Startup Tab.Â
4. Select the programs that you want to display on startup
5. Click Enable All or Disable AllÂ
6. In addition, you can opt to configure the Boot tab
7. Finally, click ok to save all the settings.Â
Ware
