Hello Viewers,
Have you ever faced the hereby attached error?
I am totally fed up with it. I need to fix it up?
Do you have any suggestion for me? Â
The following Z drive is a folder of a mapped network.
The process cannot access the file ‘Z1.Multimedia2.MoviesActionKill.Bill.Vol.2.2004.avi.tgmd’ because it is being used by another process.
Please help.
Mapped Network Error: The Process Cannot Access the File
Hi Nimbus,Â
This type of errors pops up very frequently some times with me, as I had not mapped my drives, then also this type of errors pops up. There would be little bit difficulty while you are working for a serious project.
As it can be solve out just you have to close the program forcefully, which ever is accessible by another application.
Here are steps:
Press ctrl, alt and delete key, simultaneously.
Task manager would open, then go to process tab.
Here, you would see all the programs which are currently running on your system.
Choose the program in which you used that file and right click on that then select end process.
Here we go. Now this error won't pop up.Â
