Lee Owens
50 points
Posted on - 07/08/2012
MapQuest is an iOS application wherein, like Google Maps, it can give you a turn-by-turn navigation service. There is a voice prompt, displays route on the map or give you a list of turns on your preferred route. The best thing about this application is that it is free. Does it also consider live traffic situation on your preferred road?
MapQuest free for iPhone users
Yes, MapQuest takes into consideration live traffic and updates as you go along. Another great feature included with the live traffic is tips for the direction that you are headed. You can also drag locations and get 360 views and you can even personalize the map that you are using. It includes a toolbar that helps you find hotels and restaurants in the area you are.Â
Hello Lee,
MapQuest can show you live traffic on your desired route . Try this link https://www.mapquest.com/?layer=traffic. It gives you directions, road conditions, traffic on local maps. Below are the things you can check on MapQuest.
1. Travel blogs
2. Booking for a travel
3. Gas prices
4. Route planner
5. Business listings
6. Enterprise planners
7. Mapping tools
8. Satellite maps
9. National parks
10. Live traffic
The link above will take you to a page where you can check all the above features in relation to your local map.
