Hi! Lately,
I have been experiencing run time errors during program execution. For example, I have serious mathematical errors that do not add up, a division by zero, invalid user input and obvious resource in/output issues like the file is missing.
How can I resolve this problem?
Error:
Marks Mortgage Calculator
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue.
If you click Quit,the application will close immediately.
Attempted to divide by zero.
Details Continue Quit
Marks Mortgage Calculator Program Execution Error
It’s hard to say if this is a system incompatibility issue since this application has other counterparts. The version of mortgage calculator that I was able to find is from a web site called A Mortgage 4 You. Since I think this is not the version you are using, try visiting the web site again where you downloaded the program and check the page for the system requirements of the application. You need to know it to determine what’s causing the problem with your application.
You may also try reinstalling the application. Uninstall Marks Mortgage Calculator from your machine then check your computer for any possible errors. Use a disk utility application to check the system.
Install the application again after this and do a test to know if it works.
