Hi guys,
I am an android user currently using android 2.3, I am looking for software that can enable me to carry out my mass spectrometry work on my android, I understand that there are many pc solutions for this so I suppose there must be a mass spectrometry android tool available.
If anyone can help me by telling me where I can find this software then please reply to the post, thanks guys.
Mass spectrometry software for android
Hi Bernard,
There are some apps for this purpose but in particular for mass spectrometry I Would recommend "Chemistry Lab Suite". It is a free app with great features and therefore is definitely worth installing and having it in your mobile.
This app is grouped in four sections:
1. Solutions (Solutions & Buffers)
2. Proteins (Proteins, Peptides & Amino Acids)
3. Peptide Synthesis
4. Chemicals (Chemicals & Elements)
Is one of the best apps to be used in the peptide chemistry field, mass spectrometry and lab work for general purposes .
Cheers,
Frazier
