Master data services Configuration Manager error SQL Server 2008 R2
Hi All,
I managed full installation of my server from scratch and did it in this order:
- Windows server 2008
- Active directory with DNS
- SQL server (all services running as administrator)
- IIS
- Master Data Service (MDS)
As MDS was completely installed the configuration manager was also in progress. I faced the error as follows:
“An unexpected error occurred: Some or all identity references could not be translated.”
I had also fully installed similar systems in different servers although without IIS. It is good that I faced no errors, yet no doubt without IIS I was unable to go very far in the MDS configuration! And basically I need to install SharePoint 2010 too therefore I really do need IIS!
Is there any option regarding this matter that you can suggest please?
I thank you for your kind help.
