Hello Friends,
I have been searching for Matching Pairs game code C language, for me to understand the working of the coding. Can anyone help me by providing me the same, Any simple C Coding will help me.
Please Help,
Archer Schleifer
You can use text editor to create source code file. The instructions you can give the computer are stored in a language understood by computer called C language.
After giving instructions in text editor, files are saved in extensions depending on the program. In this case if you create a game called UFO KILL it would be saved in C extension, UFOKILL.C.
The final program file is then created by the linker that ends with an extension EXE.
