Today I am typing math paper for school class children. For math symbols I use math type software after writing symbols in this software I move these symbols in Microsoft Word file.
Before 2 days this is working properly for me but today I try then I receive given error. Tell me solution.
Microsoft Word
MathType has detected an error inULibCls.Error running
Cmd = NoDirectCall-InsertRightNumberedDispEqn mod = UILibCls in
RunMTDLL Command. Please save your document and report this error to Design Science Technical Support.
OK
Hello my friend, the question you arise here is a generic one and most of the individual found that as well. Basically the symbols specially the formulas of the math type are not supported in originally basis by the Microsoft word but it supports in a sense when someone is trying to copy it from any other source.
So my dear the solution for you is that here it shows a runtime error means that those all mathematical calculations and formulas are creating a problem.
So now you can again open that file in the mathematical software where it was saved by you and then install a new copy of word document and then copy again that math file in a new word document and do scan it from viruses.
Thanks dear.
