This is a problem, I have MaxData 4000A notebook with integrated wireless card.
When I want to connect to desktop PC with wireless password and when I enter that password, I get this error:
"The network password needs to be 40bits or 104bits depending on your configuration.
This can be entered as 5 or 13 or 10 ASCC characters or 26 hexadecimal characters.
Wireless configuration
The network password needs to be 40bits or 104bits depending on your network configuration.
This can be entered as 5 or 13 ASCII characters or 10 or 26 hexadecimal characters.
MaxData 4000A noteBook Wireless Network Connections Problem
Network security can be set to this type ASCII characters, 40bits or 104 bits, 128 bits, 64 bits, 26 hexadecimal characters depending on how you will set-up your network security key.
This can be set and can be change by logging in to the internal settings of the router. Log-in to GUI, 192.168.1.1 or it depends on what default gateway your router uses.
Log-in with the username and password and go to Wireless tab. In this page, it'll display the network name or SSID and the channel it was set. Go look for wireless security tab and this should let you set the settings to the configuration what is needed to.
See screenshots for better understanding.
