The maximum number of video clips is 99
Hello friends. I have a high definition camcorder which I used in my last business trip. I recorded a total of 300+ clips. But when I attempt to add clips in DVDMF7, I received an error "The maximum number of video clips is 99." The output for 99 clips will be 37 minutes and will need a total of 4 DVD disc to record all the clips. Is there a way to combine the four clips together? And then combine those joined clips to four different times? Do I need any software to achieve this? Please help.
Answered By 20 points N/A #109417
Hi Eli,
There is a setting for the application that it can only allow about 99 chapter. So its thinking your adding more than 99 chapters instead of clips or titles. Yes, you can try to add up to 99 clips first on your video. Once you are done with the 4 clips, you can then add them together. You just need to choose Join Video then click on Join clips on the ones with available buttons on them.
Once you are done, you might experience for your application to crash. You may want to wait for your application to finish loading and the blue and red light to stop flashing before you try to use it so that it will not crash.
Aristono
