Maximum range of wireless Xtatic Air
I am going to buy the X-tatic Air Wireless headset.
But I need to know 1 crucial thing .
What is the maximum range of the device ?
Hello James,
Sharkoon products are very effective and reliable. For buying the recently launched xtatic air wireless headset knowing the maximum range will be very useful to you. It has a maximum range of 10 meter.
That means it can operate as a wireless headset up to 10 meters farther.
Thanks
Hey there James,
Very nice decision on choosing Sharkoon's X-tatic Air Wireless, not only that it has a huge range of its wireless connectivity, this headset also works in most consoles available. Definitely a perfect gift to all game lovers out there. If you like to see some unboxing video regarding this headset then check The below Video.
For full specifications regarding this product you may want to visit Sharkoon website.
I hope this helps and enjoy your new headset.
Waall Mike
The X-Tatic AIR wireless headset is a wireless gaming headset designed mainly for Xbox 360 and PlayStation 3 gaming consoles but can also be used on your PC, Wii including TV sets, and other sound sources that supports RCA audio outputs. The wireless headset uses 2.4 GHz digital transmission technology. This ensures clear voice and gaming sound within a radius or within a range of about 10 meters away from the console or from the transmitter unit.
The enclosed NiMH batteries can support up to 10 hours of gaming sessions. This wireless headset is specifically designed for gamers. If you plan doing an extensive gaming session, you can charge an extra set of AAA batteries for the headset inside the battery-charging station of the transmitter. The battery-charging unit can also charge AA batteries.
