Maximum Sites a Site Builder Can Handle
How many sites a site builder per server can handle and what are the parameters and specifications do I need to have for me to run more than 200 sites? Some help please?
Dear user,
There are no specific requirements of the number of sites for server, the number of sites per server depends on the purchased license you have. Your site's license key will limit the number of sites. Number of sites also depends upon how much HDD capacity server you have. Also depends on how much you bog down on your server. If you your server to work properly, without any issues, you must add sites to your server until your C.P.U reaches a limit, make that limit yourself and don't let your server exceed it.
Hope this will help you.
Thank you.
