Maya fatal error attempting to save in C document
Hi there,
After the system upgrade to latest versions, I am facing this problem with Maya. Not able to work with it like before and when I try to save the document it throws me a fatal error message. Do I need to update the software too? Does the system upgrade affect the existing software in the system? Please help. Thanks.
Maya
Fatal Error. Attempting to save in C:/DOCUME~1/reillda/LOCALS ~1/Temp/reillda.20100603.1008.ma
