McAfee Errors when Checking Mails in Outlook Express
This error occurred when I tried to check my mail in Outlook Express. The error is stating:
“Error found in Custom UI XML of McAfee AddIn; Line: 1, Column: 118, Error Code 0x80004005, Unknown Namespace: //schemas.microsoft.com/office/2009/07/customui, Element: Custom UI. ”
And another error message appears when I hit the OK button on the first error message:
“Error found in Custom UI XML of McAfee AddIn, Line 106, Column: 11, Error Code: 0x80004005, The node is neither valid nor invalid because no DTD/schema declaration was found. ”
After these two error messages, I was able to check my mails. I also found another error that says “DAT out of DATE” after running McAfee Virtual Technician which I cannot fix myself because it is resulting to the same exact error after attempting to fix it. And one more error occurred when I tried to consult an online technician via chat. The message says that:
“A problem has occurred which has caused Explorer to close and re-open this window. ”
And the chat window disappeared. I need someone who can help me resolve this problem. Thanks you so much.
