McAfee Firetray Exe System Error Problems No More!
I am frustrated seeing the Firetray exe system error. I have googled about it too much already. How should I solve this error? Thank you, please help me out.
Hello and welcome friend, “.exe” files are execution files which adorn an important role in any software, and “firetray.exe” is related to McAfee Host Intrusion Prevention software which is developed by Windows. You are greeted by this error when you open or close McAfee HIP. This error can occur if your “.exe” file gets infected by Trojan, suspicious malware or any other virus. Hence, it is important to solve this issue. You can do this by:
One important point that you should register in mind is that you should never attempt to download these type of files from unofficial websites as they are not verified from their respective developers, and you may unintentionally invite virus within your computer.
Option no-1: Remove and again install McAfee HIP
Option no-2: Execute an Anti-virus scan from reliable software:
Thank you.
If you are experiencing a problem with your McAfee software, check first your subscription if it is still valid. You usually get problems with your antivirus or internet security when your subscription is expired. If you no longer have a valid subscription or it is already expired, renewing your subscription should fix the problem.
But if your subscription is still active or valid, try to uninstall and reinstall the program. Download the free version of Revo Uninstaller and install it. Once installed, start Revo Uninstaller then select your McAfee antivirus among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, close Revo Uninstaller then install your McAfee antivirus back. See if this works.
