McAfee Security error when launched automatically on startup.
I have set my McAfee security to be automatically launched at my start up but I get this error message every time I turn on my computer.
“Internet Explorer Script Error:
An Error has occurred in the script on this page.
Line: 277
Char: 2
Error: ActiveX component can't create object: 'Scripting.Dictionary'
Code: 0
URL: mcp://C:PROGRA~1 mcafee.comagentRegWizUI.dll::default.htm
Do you want to continue running scripts on this page?”
Best Answer by carol_brown
Answered By 0 points N/A #86882
It is best when you turn on your computer and there would be automatic scanning of files done by your antivirus software. That is one of the best ways to refrain your computer from foreign invaders. About your problem, I only got one solution, when you encounter this kind of problem.
Turn on your internet connection always to prevent from errors because during this stage, the scanning of files is automatically done by the antivirus software. I hope my solution can cater the problem that you have right now.
Answered By 0 points N/A #86884
I have read out your problem. Actually it is a general scripting error which happens due to missing Windows script runtime library or its registration is missing. First try this script hope it will help you: regsvr32scrrun.dll.
Type the above in Start > Run and then press Enter. "Restart the windows" if the scrrun.dll file is missing or if the above registration does not give any help. Then you may need to download the latest scripting updates from the Microsoft site.
Click this link to download the latest script. This will help you to find the solution of the problem if you follow the mentioned steps properly. Best of luck. Have a good day.
Answered By 0 points N/A #86885
For the solution of your problem you should disable the pop up blocker of your internet browser first of all and then set up the privacy and security settings to medium level. After these two process you should clear all the history of your" Internet Explorer or Firefox" including cookies, caches and login details as well.
If the problem persists then you should uninstall the current McAfee security software and try to download an update version of it and install after downloading it. I hope that this problem will resolve by following the above steps which I got after an amazing research and experience.
