McAfee Virus Scan Plus update error occurred
Hi everyone,
Hi everyone,
Yes, I care to spare my ideas in helping you. Your McAfee Virus Scan Plus is genuine, as what you mentioned your subscription has not ended. The error message that pop-up on your screen is prohibiting you to secure your system against viruses, so I recommend you to restart your system and try again to re-update again your McAfee Virus Scan Plus, if the same problem occurred contact the McAfee Intel Company regarding this issues go to this siteÂ
https://www.mcafee.com/us/about/contact-us.aspx
Best regards,
Heather marie
Hi Helenmarmstead,
First of all, make sure that you activated your copy of McAfee antivirus. Though your subscription has not yet ended but not activated you cannot update your antivirus, it’s a very simple step to start an antivirus program. You will give your email add and some details about you.
