MCE system with Ceton and Blu-Ray recording problem
I have Windows 7 MCE system with Ceton InfiniTV and TMT5 for Blu-Ray. I am facing some problem with the recording. It is getting stopped randomly. No other tuner applications are installed. That’s why I done know any other service will solve this problem. It is not happening because of manual intervention. Please help me to fix the problem. I will thankful for all help and support.
Answered By 55 points N/A #94179
Which graphics card are you using? There are few AMD cards that has this problem and the only way to fix them is to replace the card. But there is no way if you have the Nvidia Card that this problem could have happened.
First in order to do anything to solve this problem, update your drivers in both cases. Download the ATI Catalyst if you have the AMD card. After that try changing your Ceton card because there is a chance that it is broken.
There is also some problem with windows media center in windows 7. It is a little bug which microsoft is trying to fix but hasn't been able to fix it.
