I’m trying to set up a Mdaemon Gmail account.Â
Is it possible to get my emails from my Mdaemon to my Gmail account?
Plus I want to manage those emails from my Gmail account.
Is this possible if not, what are the limitations between Mdaemon and Gmail?
Mdaemon Gmail and limitation between the two
The first thing you should know when opening an email account, is that; there is a unique name which the system requests you to find. This name is called user ID. The system accepts one name per person.
So if you choose your Id with upper case, the system can only accept that. If you try to change an ID for lower case, the system cannot log in. In other words, the system for Gmail is case sensitive.
So Mdaemon and MDaemon are two names different you can’t share them. Google has more solutions for you.
