Measurement and Automation explorer error
I was trying to install MAX which is a measurement and automation explorer. I was able to download it from LabVIEW but the setup cannot be initialized. What should I do?
Also can someone suggest MAX alternatives so that if this fails completely I can switch to the other one?
The Operation could not be completed. Operation failed with error code: 7409
Operation failed.
Answered By 0 points N/A #181489
Please check that the target and the host reside on the same subnet. There should be no conflict of the IP address conflicts. Make sure to assign a unique IP address to each controller (in case of multiple controllers).
Also, eject the Compact Flash card from the controller and insert it to the Flash Card Reader. Reformat it using FAT mode.
