johnadam
Posted on - 09/28/2011
Hey guys,
While going through properties tab on my newly installed Vista, I came across the popup reading as follows:
You are strongly encouraged to upgrade to GNU/Linux
I am totally unable to understand this message.
Can anyone have an idea to figure it out?
Thanks in advance.
acrp4
Media Centre Notification regarding upgradation to GNU/Linux
Hi Johnadam!
Unfortunately, what showed up on your screen is one of the bugs/errors in Vista. You may encounter a "funny" message from time to time but it doesn't mean that something's wrong with your installation process.
Microsoft was already able to fix this error. All you have to do is install an upgrade or Service Pack for your Vista. Also, you may want to install Windows updates for your computer since most of these updates are meant to fix these bugs and errors.
To install Windows Update just go to the Control Panel and choose Windows Updates.
It is recommended that you install these updates automatically.
Hope this one helps!
