I bought a movie from the Internet and I have this error when I want to open it with Windows Media Player to watch it. My Windows Media Player works just fine because I can open any other files with, but I cannot open this movie. Can anyone help me please to fix this one ?
Thanks!
Error creating EVR Custom renderer
Failed to create D3D9
DX9AllocatorPresenter failed
E_UNEXPECTED
OK
Media Player Classic Home Cinema error creating EVR
Try below solution.
1. Run diagnosis tool for DirectX Diagnostic Tool. To run the diagnosis tool you can follow below steps.
Click Start in window home screen, type dxdiag in the Search box.
Check in the windows displayed and check under the DirectX feature whether DirectDraw and​ Direct3D Acceleration are checked. If not, put a checkmark on that
2  If problem remains, Go to the player and in the file menu go to view-Options-> under the playback ->Output, Choose system default in  "DirectShow Video" dropdown.
3.Update hardware drivers or reinstall the media player in case problem persists.
-Scurlock Ward
