Meizu Mx mobile information ?
Hey, Guys I want information regarding one mobile Meizu Mx mobile which looks like iPhone. I want to buy that mobile ? Can anyone list the sites which sell that mobile?
Meizu MX mobile is one of the Android smart phone which come with the almost similar features of other Smart phones. This mobile can be bought from the link below. The mobile comes with features like
Processor : Cortex A9 1.4 GHz
SIM : Dual Sim
OS : Android 2.3
Memory 1 GB ram , 16 GB ROM
Network 3G
Camera : Front 0.3 MP, Rear 8 MP
Its a touch screen mobile with rest all same features as other Smart phones.
Supports java based application.
https://www.gsmarena.com/meizu_mx-4373.php
The Meizu MX Smartphone is a 3G device operating on 2G and 3G network bands using GSM and HSPA technologies. It was unveiled on December 2011 and released on March 2012. It measures 121.3 x 63.3 x 10.3 millimeters and weighs 139 grams. It uses a micro-SIM card. It has an ASV capacitive touchscreen display with 16M colors at 640 x 960 pixels screen resolution.
It supports multi-touch and runs on Android 2.3.5 Gingerbread upgradable to Android 4.0 Ice Cream Sandwich powered by Exynos chipset, Dual Core 1.4 GHz Cortex-A9 processor, and Mali-400 GPU. Unfortunately, it doesn’t support microSD. It runs on 1 GB RAM with 16 GB internal storage. The primary camera supports 8 megapixels with f/2.2, LED flash, and autofocus. The primary camera features WDR, geo-tagging, and smile detection.
The primary camera can record video in 1080p at 30 fps. It has a secondary VGA camera. It has 3.5-millimeter jack with Active noise cancellation with dedicated mic support; Wi-Fi 802.11 b/g/n with hotspot support; Bluetooth 2.1 with A2DP and EDR support; GPS with A-GPS support; and microUSB 2.0 with MHL TV-out and USB Host support. It doesn’t have a radio.
It has built-in accelerometer, compass, gyro, and proximity sensors. The pre-installed web browser supports HTML with Adobe Flash Player support. Java is supported via Java MIDP emulator. It runs on a non-removable Li-Ion 1600 mAh battery and available in black and white colors. It costs around 270 Euros.
Hi
Regarding on your question there is another Techyv post which one will be helpful for you.
Pay a visit this link : How are meizu phones complete touch screen.
Notifications
