I installed AutoCAD without any error. I can not patch it because when I am going to patch, it shows an error message. I need your help. Can anybody tell me the reason? I am using 64 bit configuration OS with windows 7.
Mem patch shows error in my laptop?
Hello
If you need to avoid this sort of problems, you need to do the follow.
When you log onto your computer, scan your computer complete from the virus.
Clean your history and cache memory.
Make a separate drive in your laptop and save the date on that drive never save your important data into that drive which you have the windows.
Proper shutdown your laptop
Here the link below which help you more to solve your problem.
Thanks,
Stella.
