Hello! I just bought Xbox One and I noticed that it has an internal memory of 500 GB already in it. But if one wants more memory, there is a way to add more memory to Xbox One internally right? Is it possible or not? If its not possible then obviously we will use external memory for it, right? Thanks!
Memory Capacity of Xbox One
The “Xbox One” has 500 GB internal memory when you buy it. There is no way to add more memory internally to the “Xbox One”, but you can extend your memory by using external hard disk.
It is not possible to add the memory internally in the “Xbox One”.
Yes, you can use external hard disk for extending your “Xbox One” memory.
Hope this answer will help you a lot.
