blackjan
Posted on - 10/09/2011
I play KOS and RAGNAROK Online last night.
When I’m in the meddle of Playing online games.
My computer display BLUE SCREEN.
I restart my computer. Then my computer back to normal
On the next day I play again, then its appears a BLUE SCREEN again
So I restart it.
The blue screen appears over and over until now
What would I do????
Please give me some advise what should I do
Thanks
Blackjan
rabin
Memory Damps Blue screen of Death
Hello Blackjan,
Is this happening to your other online games or only in Ragnarok and KOS? If this happening to your all online games this might be the end of your memory and its already near to be dump. The life span of your memory is going to be end and you need to replace before all your computer hardware may afffect.
You should prepare for a fresh one and buy a higher memory for a good performance with a smooth gaming. As of now if you can still use your computer and you are tired of seeing that one. Better to enhance your specs of your PC if you are trying to play a higher system requirements of online games.
Thanks,
Rabin
Check when you usually see the blue screen error. If you only see it during a game session then you probably need to check your video card. First thing to do is try to update the video card driver. Try downloading the latest video card driver from here if you have one of these:
If updating the video card driver doesn’t work, the only solution left is to replace your video card with a new one. If you are using your motherboard’s integrated video card, you need to buy a dedicated video card.
