Memory help on the intel core i7 5930k
I decided to go for the new Intel Core i7 5930K Haswell-E CPU for use with the Asus Rampage V Extreme Intel X99 Socket Motherboard. I would have gone for Corsair Dominator Platinum 16GB DDR4 2800 MHz but settled for the Corsair Vengeance LPX 16GB DDR4 2666 MHZ to save some money.
Answered By 0 points N/A #187596
Hello Justin!
I assume that your question is if the memory that you bought will work with your core devices? Yes it will! The only difference that this memory will process slower than the other memory you mentioned. Saving money isn’t bad especially if you’re assembling computers. The only question is how long will it last rather than having the expensive part of your computer. There are other ways to maintain good working computer by installing proper system to avoid system clash that will cause damages to your system parts. Avoid jumping into any conclusion of cleaning the parts of the system. There are only parts that needs regular check-up and sanitation requirements.
