Kamal Hasan
Posted on - 08/09/2011
My PC have 4GB RAM with windows 7 OS (32 bit). I hear that windows 7 (32 bit) does not support more than 4GB RAM. Is it true? I want to add extra 2GB RAM more. What can I do? I use MSI 880 GMA E-45 motherboard.
Memory (RAM) Requirements for Windows 7 32-Bit Installation
You requirement 2GB of ram as a peak for Windows 7, 64-bit, but fair 1 GB for the 32-bit variant. Since 32 bit can't use 4 gigs of ram, most new consumer computers turn with win 7- 64 bit. It's a consumer OS. Windows often times uses nearly the corresponding total of memory as the 32 bit type for numerous things, though' pointers to things moldiness be 8 bytes instead of 4, and in imprecise the operative scheme is optimized to do large things without harassment nearly memory speech limitations. Presented that the x64 command set is in whatever slipway many timesaving, viable inscribe of times takes nearly the Synoptically quantity of set..
This is Not Mandatory That You'll Use Only The 4 GB Ram at Windows 32 Bit Or 64 Bit …
 If You Have Some Extra Slots At Your Motherboard For Ram .. Then You Should insert it !
 It Will Definitely Speed Up Your System !
