Memory shortage in drives – need to integrate
I have some memory storage issue in my drivers, and I need to integrate some of my drives together for additional space.
For this shortage I am unable to install some of the necessary software's for my job.
Should someone know how to merge multiple drives together kindly inform me.
Scott Martin
Answered By 590495 points N/A #109400
If you will be doing some drive merging on your computer, try installing PowerQuest Partition Magic on your machine. This is a great tool for partitioning hard drives. PowerQuest Partition Magic is already obsolete and its official web site was bought by Symantec that’s why there are no more new releases of this application.
But you can still download this partitioning tool in other web sites. After Symantec bought the company, they released their own version of Partition Magic using the brand name Norton Partition Magic. If you can’t find PowerQuest Partition Magic, try searching for Norton Partition Magic.
Download and install it on your computer. After installing it, you will see the Merge command there. This is the command that you’ll be using. First, select the drive that you want to merge. After clicking on the drive, click on Merge then follow the onscreen instructions. After merging the drives, the contents of the other drive will appear as a folder on the new drive.
All files are intact. Just move the files anywhere you want after the merge.
