Memory storage of notebook and laptops
I want to know whether Notebook has a better memory storage or Laptop. I have to buy a Notebook but if it has less memory storage as compared to dual core Laptop then its of no use.
Please guide me.
Please guide me.
Hey Anam,
It depends on the specifications of the Laptop or Notebook. However, if you bought Notebook and found it slow, you can upgrade your Memory Storage. Similarly you can also upgrade your Hard Disk and your processor of Notebook.
Yes you can Check your memory usage by pressing Alt+Ctrl+Delete in XP and 7 can do it as well. If your memory not enough, Just install new memory and speed up. But before buying check other higher ram value laptops available in cheap price than installing.
