Hello, notify the various other problems for microsoft visual studio express 2013 for windows desktop and also brief for its specifications in detail as well with its steps one after the other for the guidance too and thanks a lot
Mentioned For Microsoft Visual Studio Express 2013 For Windows Desktop And OS Too.
Hey, the microsoft visual studio express 2013 for windows desktop are supported in many of the cross platforms too and they have many windows OS too for their supports as well. They are supported in windows platforms such as windows 7, windows Sp1, windows server RS SP1 and many others too. The systems specifications for it are listed down:
- The Hdd space is 4Gb or more
- The RAM is 2Gb or higher
- The processor must be 2.6 GHz
- The RPM for the HDD is minimum 4400
- The display resolution is 1028 x 768 and above.
If you need to install Microsoft Visual Studio Express 2013, you need to check the system requirements first and verify that your computer meets those requirements. Microsoft Visual Studio Express 2013 supports Windows 7 Service Pack 1, Windows 8.x, Windows Server 2008 R2 Service Pack 1 (64-bit only), Windows Server 2012 (64-bit only), and Windows Server 2012 R2 (64-bit only).
It requires 1.6 GHz or faster processor, 1 GB RAM, 5 GB free space, and Microsoft DirectX 9-compatible video card at 1024 x 768 minimum screen resolution. Windows Update “KB2883200” needs to be installed for Windows 8.1 and Windows Server 2012 R2. You can get it via Windows Update. For the download, go to Microsoft Visual Studio Express 2013.
