Mentioned The 80070103 Error Code With Steps
Hello, mentioned for the 80070103 error code and notify the steps for the guidance too also reply soon and thank you very much as well.
Hey, the steps for the 80070103 error code are as follows:
You may receive error code “0x80070103” when you are trying to install a Windows Update. The error is not technically serious. It only means you are trying to install a device driver that is already installed on your computer. It can also mean that Windows Update is trying to install a device driver that has a lower compatibility rating than the one that is already installed on your computer.
In other words, the driver that is currently installed is better than the one you are installing. If you receive error code “0x80070103” when you are trying to upgrade to Microsoft Windows 10 and the error tells you that the video card driver is not compatible, try updating your video card driver. Visit your video card manufacturer’s website and download the latest driver for your model.
But if you know the driver currently installed is the latest, one workaround is to hide the update. If the driver is working properly, it is not important to install the update. To hide the update, click “Start” then in the search box type without quotes “windows update”. Click “Windows Update” from the results. On the left pane, select “Check for updates”.
Click “Optional updates are available” then select “Optional”. In the “Select the updates you want to install” section, look for the update you want to hide, right-click it, and select “Hide update”. Click “OK” and that’s it.
