Mentioned The Error 401 Magicjack And Products Too.
Mentioned the error 401 magicjack and the value for the products as well with some features for the same too and thanks you as well and revert soon as well.
Answered By 50 points N/A #290788
Hey,
The error 401 magicjack is a magic jack product which has a 1 year warranty for the same and will cost you Rs 2300 or more as per the products you go with too and the errors may occur due to wrong connectivity to the other ends like to the computers or other devices s well. The features for the same are as follows:
  • Can be connected to the modems with high speeds
  • Has the clear voice facility too
  • Can connect the calls to anywhere in worlds
  • Also get connected to the computers as well.
