Mentioned The Random Number Function In Excel In Steps
Hello, notify about the random number function in excel and the steps for the same as well. Thank you and reply ASAP as well.
Hey, the random number function in excel mainly returns the random number which is greater or equals to 0 and is also less than 1. Also it returns the new random number each and every time when the spreadsheet is calculated. Below shows the steps for it as well:
• First select the cell A1
• Next type the RAND() and then press enter.
• Next for generating the random number, you have to select the A1 cell
• Later click on the lower right side corner of A1 cell and drag it toward downside.
• Now select the cell C1 and go for the formula bar.
• So this cell holds the value not the rand functions.
