Mentioned the wd acronis true image review for reference.
Notify the wd acronis true image review and the price for the same too as a reference only and thank you for it as well and revert soon.
Hey,
The wd acronis true image review comes with both the trail pack as well the paid ones too. The trial pack for just 30 days and can use the same too after that period the price will be Rs 3500 or equivalent as per the OS your are using with. Also it uses the feature of backing up as well and also the applications are developed for the same in the Smartphone’s too. Below shows the supported OS:
• Mac OS X
• Windows 10
• Windows 8
• Linux
The Acronis True Image WD edition is a backup software that allows you to backup your applications, your entire data and settings, and operating system while shredding any confidential data you may no longer need. Aside from that, it is also capable of cloning your drives making a total backup of what’s stored in that drive.
The application also provides you with all the tools you need to be able to recover your system in case of system failure or any form of disaster that can happen like accidentally deleting critical files or folders, losing data, or a complete hard drive crash.
If a failure happens and it blocks access to information or it affects the system operation, Acronis True Image WD will help you easily restore the system and the lost data. Acronis True Image WD edition supports Windows 7 Service Pack 1, Windows 8.x, and Windows 10. Windows XP and Windows Vista are not supported in this version.
Note: this application is designed to work with a Western Digital hard drive. If you don’t have one, you cannot install and use the application. If you have a supported operating system and hard drive, download the latest Acronis True Image WD Edition 2016 Build 33 or visit Acronis True Image WD Edition for any latest update.
Notifications
